Hello, I am addressing connoisseurs of double and multiple star resolution. I would like to know which cameras, in monochrome version, is the best suited to do this kind of study. The studies will be done mainly with a refractor telecope of 120mm f / 8 and a reflector (Newton) of 203mm f / 5. I would like to keep the bill under $1000.
Thank you for your answers.
ASI290MM, ASI174MM, ASI178MM, ASI183MM, ASI1600MM uncooled cameras
ASI174MM-C, ASI178MM-C, ASI183MM Pro cooled cameras.
Thank you very much for that answer.
I presume that if I want to do some deep sky images, it would be better to choose a cooled camera instead of one that does not.
If you want to get some amazing Deepsky images, I recommand cooled camera. cooling and constant temperature is very important.
maybe you are interested in this document
16 03 04 CaveCreekCameraShootoutFinal.pdf
