Hi, I'm using the ASI224 for DSO work and I'm using Pixinsight for processing. I want to use the SubframeSelector process to calculate weighting and best frames to keep but I need to know the camera gain in Electrons per data.
Do you have that info?
Also further to the conversation in this thread:
https://stargazerslounge.com/topic/255509-what-settings-for-zwo-asi224/
It seems to suggest that the asi224 bias frames cannot be used for calibration purposes because of an internal change that takes place in the sony sensor when the exposure is changed. Is this correct? Or can I take my bias, flat light and dark frames in the usual way?
