Hi,
I'm using the C# interface with an ASI 120MM, and it works normally during some hours, but after some time I can't take any video or snapshot. The only solution is to unplug the camera and plug it again, the problem is that I'm planning to place it in a remote location...
I'm getting the following error: "Value 93230 is not valid for 'value'. 'value' should be between 'Minimum' and 'Maximum'.
These are all the control values I get:
Temperature (Sensor temperature(degrees Celsius))
MinValue - -500
MaxValue - 1000
DefaultValue - 20
ControlType - ASI_TEMPERATURE
IsAutoAvailable - False
Writeable - False
Value - 93230
IsAuto - False
Gain (Gain)
MinValue - 0
MaxValue - 100
DefaultValue - 50
ControlType - ASI_GAIN
IsAutoAvailable - True
Writeable - True
Value - 9
IsAuto - False
Exposure (Exposure Time(us))
MinValue - 64
MaxValue - 2000000000
DefaultValue - 14000
ControlType - ASI_EXPOSURE
Writeable - True
Value - 14000
IsAuto - False
Offset (offset)
MinValue - 0
MaxValue - 20
DefaultValue - 0
ControlType - ASI_BRIGHTNESS
Writeable - True
Value - 0
IsAuto - False
BandWidth (The total data transfer rate percentage)
MinValue - 40
MaxValue - 100
DefaultValue - 50
ControlType - ASI_BANDWIDTHOVERLOAD
Writeable - True
Value - 100
IsAuto - False
Flip (Flip: 0->None 1->Horiz 2->Vert 3->Both)
MinValue - 0
MaxValue - 3
DefaultValue - 0
ControlType - ASI_FLIP
Writeable - True
Value - 0
IsAuto - False
OverCLK (Over clocking percentage)
MinValue - 0
MaxValue - 30
DefaultValue - 0
ControlType - ASI_OVERCLOCK
Writeable - True
Value - 0
IsAuto - False
AutoExpMaxGain (Auto exposure maximum gain value)
MinValue - 0
MaxValue - 100
DefaultValue - 50
ControlType - ASI_AUTO_MAX_GAIN
Writeable - True
Value - 50
IsAuto - False
AutoExpMaxExpMS (Auto exposure maximum exposure value(unit ms))
MinValue - 1
MaxValue - 60000
DefaultValue - 100
ControlType - ASI_AUTO_MAX_EXP
Writeable - True
Value - 30000
IsAuto - False
AutoExpTargetBrightness (Auto exposure maximum brightness value)
MinValue - 50
MaxValue - 160
DefaultValue - 100
ControlType - ASI_AUTO_MAX_BRIGHTNESS
Writeable - True
Value - 100
IsAuto - False
HighSpeedMode (Is high speed mode->No 1->Yes)
MinValue - 0
MaxValue - 1
DefaultValue - 0
ControlType - ASI_HIGH_SPEED_MODE
Writeable - True
Value - 0
IsAuto - False
I would appreciate any help. Thanks!
