Hi,
I just need to verify the correct spacers to use when using an ASI 294 Pro with the EOS T2 Adapter. I have it set up the following way:
294 Pro
11mm F-F adaptor
EOS T2 Adapter-minus the 5mm extension that came with the adapter
Internal 2" IR/UV Filter
Rokinon 135mm lens
Is this the correct setup? I have not imaged with it yet due to weather.
Thank You
Bob
