In video stream my asi 1600 mm can not exceed 1.4fps (regardless of the resolution) even with a usb 3.0 connection. . I use Firecapture 2.6 or SharCap on a PC asus with Intel processor i7 (windows 8.1). I downloaded the last dirvers. I do not understand ! My asi 120 works with full resolution at 18 fps.
1°) Thank you to tell me what parameter I have to change to reach the advertised rate ?
2°) Another question: Can I use connections with a "Silex DS 600" to connect the asi cameras to the PC?
Thanks a lot for your answers.
Etienne
