We checked the files, and found two thing might be incorrect.
1. Flat frames brightness is too low, usually we recommend the brightness median value at 25000ADU-30000ADU. but your flat only have 13000ADU.
2. Flat frame can't calibrate the light frame. I did test use Master_B_flat to calibrate a single B light frame, B / master falt B. But looks the flat can't calibrate perfectly.
3. Master flat need to calibrate each single light frame at frist, then stack all calibrated light frames.
I recommend take new flat frames, redo the calibration.
