My imaging setup is a SW Pro 100ED, SW 0.85 FF/FR, ZWO EFW with Baader 36mm un-mounted LRGB, Ha, OIII, and SII filters, and the Pro version of this camera. I have 16.5mm and 12mm extenders that gives me the required 55mm back focus to the camera sensor. I am using the latest ASCOM driver from your site installed. I have read on this site that the offset is set to 50, and can no longer be changed in the driver.
I use SGP v3 to capture my images, and also created darks and flats calibration frames. My post-processing is with StarTools. This is the result of 45x60 sec exposures with a gain setting of 71. The first image is what I see after AutoDev, and the second is after Wipe in StarTools.
I am not sure if I am doing something wrong or if there is a problem with the camera. Any suggestions are welcomed. Thanks in advance.
