The Quark has a built in x4 telecentric, so the final focal length is much higher.
I'd try the ASI 174.
Any frame rate will be always be secondary to the chosen exposure time, but around 20-30 fps will effectively "freeze" some of the poor seeing.
(On the spectroheliograph I use, where I only record the spectra line of H alpha, I can get up to 400 fps)
The NR are caused by interference (when using very narrow band filters - like the H alpha etalons) between the surface of the CMOS chip and the glass cover plate. Not all cameras are affected. The ASI 183 has an AR coated cover plate which I think may help.
For me, the T2 tilter works.
Hope this helps
