1. What is the operating temperature range? Escpecially the lower temperatures?
it based on PI, so temperature range is the same of PI, maybe -5 to 40 degree, too high temperature lower the performance
2. What is type of power input connector is used?
we will provide one 12V-5V DC converter to work with it
3. Does the ASIair operate on 5 GHz wifi? The 2,4 GHz wifi channels are mostly crowed by neighbor networks which drops down the bandwidth alot.
yes, it supports 5G and 2.4G, you can switch between them
It looks like the internal hardware is some type of raspberry pi. Right?
I am also using some raspberrys for accessing my ASI cameras via Wifi for a while. I think the micro usb power connector is not very stable. I think a 12 V DC plug like on your cooled cameras will be more handy.
I think the DC converter make it more stable
