Hi, does this thing, like PHD guiding, or EKOS/indi also support various mounts, cameras or even active optics?
Focusers and filter wheels would also be interesting for many people, I guess...
I also always think whether I would add an usb focuser that is ascom/indi controlled...
For me, support for the starlight xpress ao would be interesting. Especially if your solution can deliver fast latency times. The sx active optics has drivers for indi which are open source, so it should not be a big problem to support it in your software...
The ao itself seems to be fast enough. Using subframes/region of interest in phd guiding has increased the speed of the ao from 2.5 hz to 5-8 hz. But with a thinkpad laptop and windows 7.
A windows laptop is not really suited for fast corrections. There are so many services that run in windows, so, in theory, a box that is specialised for controlling a telescope and guiding could be optimized for fast latency guiding with an ao.
If with your box I could use the 5ms=200hz rate of the ao, and if I would get a decent 10-20 hz framerate perhaps with an ASI mini guider that supports the new usb-c standard, that would be interesting for me, if it worked....
Corrections of seeing, if they worked, may also be interesting for planetary photographers, but for the active optics, the bottleneck really seems to be windows and usb/download latency, not the ao. A thing that could be tackled with a specialised box...
Seeing really sucks and I do not want to travel to the atacama desert soon....
