Hi, Did you try manual set R and B value?
The image show green, because amost all camera have the highest sensitivity during green channel.
Also you can add a IR-cut filter to get better white balance.
If the camera is running in Sharpcap, camera is OK. the problem in Live stack will be a software problem, need to ask Sharpcap team for help.
