good day i would like to know if the connector size for powering the asi 1600 pro! dc 2.1 mm or 2.5 mm? thank you
Alberto (Italy)
Power Cable is 5.5mm x 2.1mm with Positive center pin.
You will want "heavy-duty" (22-16ga) wire, as you will be running a good portion of 3 Amps along 5-10ft of wire and will see significant DC Voltage Drop with thinner wire.
perfect ! thank you so much !
