Thank you, Chad and Gary
Last night, I could take sequence files with zero gain successfully !!
I applied computer latest program update in these......, other than this, nothing was changed.
Windows 10 pro ver.1803
SGP ver.3.0.2.82
ASICamera ASCOM Setup V1.0.3.18
ZWO ASI Cameras driver Setup V3.0.0.4
SGP did work both with native driver and ASCOM drivers.
SGP could fetch gain list with ZWO native driver. but only for gain list and off set, not for USB traffics, so far. or I may miss out the list in somewhere.
possibly, SGP is still running in beta program.
SGP could work with latest ZWO ASCOM driver. In advanced tab, I could control all list of gain, offset and USB traffic. although, I always set default.
One concern is the first download time of the sequence. I took about 90 sec to complete the first shot. I remember it was far more fast last year.
or that was my intriguing? anyway I'm not certain. The first download time is thrilling for me.
Hi, Grey
I also suffered genuine USB cable issue last year. New genuine Grey color cable had problem not to connecting electrically.
Changing to old genuine black cable solved it. I like genuine cable which is still soft in cold temperature, although, some may have the problem.
Common USB3 cable in the market will work fine, but most of the cable will change hard in cold night. I hope little bit longer on genuine cable and stable for electric contact in the cable.
Regards
Hiromu
