I am using an ASI174MC-Cool and finding that with the ASICamera2 SDK on Linux the camera temperature and the Cooler power percent status are reported as 0 all the time.
I am using the same code as in the demo software delivered with the SDK.
If I run the test_console demo software, which uses the ASICamera SDK (doc says revision 1.3, 2016.12.9), then the camera temperature is reported.
Running the test_gui2_snap software using ASICamera2 SDK reports a temperature of 0.
We are using the cooler and knowing the temperature is important.
I am using the ASICamera2 SDK from May 2017, however the change log for newer versions does not indicate anything relating to the camera temperature.
Can anyone help?
