Sean.Wang wrote:No, They both use AR coated protective window.
Protective window won't cause halos.
So the full spectrum of light is allowed in, correct? (Similar to the ASI 224).
If true, this is good news, as a cut filter (or semi-apo filter) will produce sharper stars with less halos, using my 2-element flourite refractor.
Thank you!
Steve
