Sean,
I looked again at my adapter. The springs are actual quite flat. In addition, the springs are not the issue because the adapter binds up well before the springs are even engaged by the lens. The difference I see between my 2 adapters that seems significant is that the flanges on the new adapter are significantly thicker than on the old adapter. Interestingly, the old adapter (which is loose when mated) already has the springs quite extended.
New adapter, camera side (camera thread adapter removed) showing spring very flat, this is super tight before spring even engages
Old adapter, camera side (camera thread adapter removed) showing spring extended, this is still loose
There is no way I can see that the new adapter could have ever worked. perhaps it has a manufacturing defect or tolerance issue?
Any way to get a good one sent out quick before my trip? I will gladly mail the defective new one back in exchange, but not enough time to wait for you to receive it. Even if you cannot send another before you get mine I would still like to exchange the new bad one, or at the very least get my money back, as it is completely unusable as is.
Thanks bunches,
ML
