What was the Ambient Temp while you were running this Imaging Session??
Even the 1600MM-Pro's 2-stage TEC is only capable of -40-45*C Relative cooling.
This means that if the Ambient Temp was anywhere near +20*C (68*F), then your Cooling was performing up to expectations.
And if it was Humid, like you said, then that will also reduce the effectiveness somewhat...
