Hi, so that is how this is callèd in your drivers region of interest function...
Well thats what I asked for, and yes phd guiding should support this. It should be a checkbox named "subframes" in the camera tab.... Is this there? can you connect a asi 174 mini to phd and look for this checkbox?
As for the ao, well the starlight xpress ao can be connected to phd guiding... similarly as a mount... phd guiding then just sends commands to the ao as well as the mount... and the picture for the asi 1600 behind it gets corrected
If I use the entire frame with my lodestar guiding camera and guide the mount via ascom, I get 2,5 hz but next time I will try to use subframes or region of interest in order to try to speed this up a bit...
If the zwo mini guiders also support the roi function and are more sensitive as my lodestar, I will try it also with the zwo mini cameras for perhaps a better framerate...
Thanks,
Benjamin
