Hi Sam, ;)
Hi all,
In France, Jupiter's maximum height over the horizon is less than 27°!
Very frustrating. And after a lot of nights with poor seeing conditions
and bad captures, I was finaly a little bit lucky last 7th May 2018.
The 16/9 size of ASI 385 sensor is very usefull to catch Jupiter and it's
nearest satellites. Here I choose to use a big ROI to reduce a little bit
the .Ser captures size.
SETUP :
Newtonian Orion Optics 300 mm F/D 5.3, on EQ-6 Mount
ZWO ASI 385 with Ir/Uv Cut filter + barlow 3x + ADC.
Acquisition with Firecapture.
Gain = 434.
Exposure time : 8 to 9 ms.
Frame rate : near 110 images/sec
26000 + 19000 raws captured. Near 15300 sorted out.
Manual sort out.
Registration with AS!3.
Derotation of 6 composed images.
Processing and post-processing with Iris + Photoshop.
Final image reduced to 90 % :
Final image reduced to 70 % :
Albéric
