Hello,
I have a question on the SDK control types that you can use to set camera parameters:
public enum ASI_CONTROL_TYPE
ASI_GAIN = 0,
ASI_EXPOSURE,
ASI_GAMMA,
ASI_WB_R,
ASI_WB_B,
ASI_BRIGHTNESS,
ASI_BANDWIDTHOVERLOAD,
ASI_OVERCLOCK,
ASI_TEMPERATURE, // return 10*temperature
ASI_FLIP,
ASI_AUTO_MAX_GAIN,
ASI_AUTO_MAX_EXP,
ASI_AUTO_MAX_BRIGHTNESS,
ASI_HARDWARE_BIN,
ASI_HIGH_SPEED_MODE,
ASI_COOLER_POWER_PERC,
ASI_TARGET_TEMP, // not need *10
ASI_COOLER_ON,
ASI_MONO_BIN,
ASI_FAN_ON,
ASI_PATTERN_ADJUST,
ASI_ANTI_DEW_HEATER
Am I right in assuming that not all controls are available for all cameras? For example trying to us 'GetControl' to get the 'ASI_WB_R' control on a mono camera will return null?
Also can I assume that the following controls are available on all ASI ZWO cameras:
ASI_GAIN
ASI_EXPOSURE
ASI_BRIGHTNESS
Or could some cameras not have them implemented?
Thanks,
Mike
