starscape wrote:Do you have a recommendation on a proper focal reducer for the ZWO 1600MM
camera with EFW and a F/6 80mm refractor?
Hello starscape,
Its 55mm + the filter offset, which is 1/3 the thickness of the filter. For example Astrodon filter are 3mm, therefore that offset is 1mm. Your filter offset may vary.
