Hi,
Recently got one of these cameras, it's my first OSC normally use a mono. In FC if I have the debayer option selected which bayer pattern should I select, is it RG ? and is the algorithm NearestNeighbor ?
According to the FC tutorials its best to record in mono and do the debayering in AutoStakkert or PiPP for example but first I should get the colour levels correct presumably with debayer selected then do I adjust WRed, Blue etc to get the best colour before deselecting the debayer option ready to record in mono ?
Is it normal to have the grid pattern on the screen when in mono, presume this is the colour grid does this go away once it's debayered in AutoStakkert/PiPP ?
If I select Always record undebayered RAW but preview in colour my image on screen is still in mono ?
Thanks
