Ok, thanks for your quick reply!
I've done some further testing and here's what I've come up with:
I'm using the latest beta version of Nebulosity 4.1.8, Windows with the latest version of your ASCOM driver from the ZWO website.
•When I connect to the ASI094MC camera using the Native driver the Thermal Cooling works as it's supposed to.
•When I connect to the camera via the ASCOM Camera driver in Nebulosity it pulls up a dialog box that has a pop-up menu that has two different versions of my camera. It doesn't matter which one I select; I get connection to the camera ok, but the cooling does not work.
I downloaded your ASICAP capture program and the cooling works as expected with that software so I think we can rule out a hardware issue with the camera. (I should keep Anti-Dew selected always, yes?)
So it appears that this is a software issue and since this only happens under an ASCOM connection protocol it seems logical to assume that your ASCOM driver has a bug or some kind of incompatibility with Nebulosity 4.1.8.
I will send a copy of this to Craig at Stark Labs and see what he thinks as well.
I suppose I could always run Nebulosity in native mode (non ASCOM); do I give up any capability there?
Bill
