I am setting up an OAG on my imaging scope and would like some advice on which camera to purchase.
My setup:
LX200 Classic 10" F10 FL 2500mm , pier mounted in observatory.
ASI294MC imaging Camera.
OAG (less camera!)
I have set up the OAG system using an ASI120mc to make sure both cameras reach focus together.
I now wish to purchase a sensitive mono camera to complete the system.
My question:
Am I better off with the 290MM OR the 178MM ?
Comparing the specs, the 178MM has much higher resolution, smaller pixels. and larger sensor than the 290MM. Is this more suitable for the long FL of the LX200 ?......and would i be better off using the 178MM which will give a wider FOV and more pixels?. The 178 looks to be slightly more sensitive also.
The primary use for the camera will be OAG. However, sometimes the camera may also be used for some imaging on another portable mount with a 1500FL SCT and 280mm standard zwo guide scope system.
Thanks in advance,
Bruce.
