Hi,
I have two ZWO ASI 183 cameras. The MM Pro and the MC Pro.
They are amazing. (well, except for the amp glow, but that is another topic).
The issue I am currently having is that the offset used in any image is not shown in the FITS header.
This is important to me, as I am trying to maximize the dynamic range, and I set the offset, for each gain, to be very close to zero, but without clipping (so around 25 to 250 ADU's in 12-bit, from 0 gain to 270, respectively, or "5" to "50" per the ZWO offset numbering system).
It would be really nice if the offset info could be added, because I am stacking some older images, and now do not know which dark frames to use, as I have many sets in my dark frame library, at various gains and offset, and I do not know what offset my light frames were at, and there is no way to determine it from the files. Had I known, I would have put that into the filename when saving.
Any help is appreciated.
Thanks ZWO!
Steve
