kveale wrote:Hello, I received the ASIAir and it is working well. However, I don't know how to configure Sky Safari to use ASIAir to control the mount. Any help would be much appreciated.
Hi, i ordered my ASIAIR so i'm gonna receive it into the next days . About this gadget, I should note that ASIAIR has a USB-RS232 cable from the factory. However, all Celestron AVX mounts manufactured after 2016 comes by default with a mini USB port, which should be connected directly from ASIAIR to the Handbox.
Does this connectivity works without problems? or should I use the USB-RS232 cable (hence, also RS-232 to RJ12 cable) to connect to the aux port?
Thanks !!!
