I have a ASI294 MC Pro only two months old.
I use Nebulosity to capture and processing.
I had no issues for a few weeks then after debayer the images were green. On processing the image run most were normal but then for no reason “green” which is unable to be processed out.
I checked everything I could think of and all the forums. I posted the image on the ZWO Facebook page for suggestions.
I reinstalled Nebulosity just incase, swapped the USB cable as I have another ZWO camera, used a different laptop during capture. I put it down to a one off.
However tonight same issue fine for the first hour then in the middle of of a session green and every imagine after unfortunately you can’t tell until processing. It’s not the debayer setting as fine for the previous images. Not Nebulosity as I also use with my 224 and no issues.
I thought it might have been the nearly full moon rising and moon glow the first time but last night was a new moon.
I also checked and the cooler, fan and temperatures read out were a consistent -20. Just incase a cooling issue.
I just notice when going through the processed images before is goes green the file size is 42.5MB then when it goes green in the middle of the run (nothing touched no changes) the file size decrease to 360KB on the green images post processing on the original capture it’s also short of data from 17.3MB to 17MB.
Any suggestions welcome thank you.
