What is the conversion to go from the Gain that SharpCap displays, which is 0 to 600, on their slider, to the actual gain of the ASI 224MC, which goes from 0 to 350? (0 db to 35 db).
Is the SharpCap Gain, db? That is, 600 is 60 db? (If so, I would never use that setting, as it is much too high).
Or is it a linear correlation? That is, SharpCap 600 is ZWO 350, 300 is 175, and so on?
Unfortunately, the FITS header does not display the gain or offset correctly, which is an issue with all my ZWO cameras.
Thanks!
Steve
