HI,
1, Please use the handle along with NEQ6 to test the movement of mount in four directions.
If one of them failed, i think the mount is broken, please ask the seller of mount to repair.
2, If the mount is OK, please connect the 120 with phd2. In PHD2, use manual control to test the four directions.
If one of them is not work, it should be the 120's ST4 port is broken.
3, If you have a multimeter, you can make a test.
please according to this DOC: https://astronomy-imaging-camera.com/manuals/ASICameras-software-Manual-Windows-EN.pdf
in the chapter 6, it explained the definition of ST4 pin, when one of the direction works, the pin and the common pin would be short cut.
Thanks
Chad
