Mount control with myt must be configured in tcp. Has anyone successfully got it to connect.??
this is a little hard as it not only need TCP but needs The SKY X
we can add TCP support in ASIAIR
so you still need another PI with SKY X installed
and connect ASIAIR and PI to one router
set the IP and port in ASIAIR app
then it can work
I was able to get the MYT mount to be controlled by the ASI AIR for goto, but it's very flakey. It's connected to a pc that has a wireless IP address.
rreed wrote: I was able to get the MYT mount to be controlled by the ASI AIR for goto, but it's very flakey. It's connected to a pc that has a wireless IP address.
Could you explain more about the issues?
