Hi there,
I am the happy owner of an ASI 183MM Pro, which I am (also) using for sub-arcsecond planetary imaging (through the Linux INDI driver) at a Newton focus. Because I am doing very short exposures, I am using the cooling feature only to make sure that the detector operates at a constant temperature (5 or 10 deg. Celsius, typically), in order to get consistent Darks.
Unfortunately, even when the temperature difference with ambiant is only a few degrees, the cooling fan speed seems quite high; generating both turbulence and a small, but detrimental amount of vibration in the instrument. This has a detectable impact on image quality. The air coming out of the camera is cold, so it seems to me that the camera could be safely operating at a much lower fan speed, or even fanless.
Would it be possible to add a fan speed control feature, or even the possibility to turn off the fan for small Delta-T's?
Thanks.
- Emmanuel.
