I use a ZWO ASI294MC Pro since January 2018. When I got this camera I installed the (at that time) current drivers (native: v3.0.0.2, ASCOM v1.0.3.12). I am capturing with SGP, using the ASCOM driver.
Eventually I measured gain, readout noise and dark current for my camera. Then I read the thread on CN, https://www.cloudynights.com/topic/628854-zwo-asi-1600-mc-pro-discontinued/ , #12 and #15, where Sam recommended to use the latest ASCOM driver in order to benefit from improvements that result in a lower dark current.
So on 11th of August 2018 I updated drivers to native v3.0.0.4 and ASCOM v1.0.3.18 and repeated the measurement. I got the same gain, readout noise and dark current values as before. However, I experinced that the bias stability (= reproducibility of the bias in separate capture sessions), that was good with the old driver, was very bad now. My conclusion is that there must be a severe bug in the ASCOM driver v1.0.3.18.
Today I realized that again new drivers (native: 3.0.0.5, ASCOM: 1.0.3.21) have been released at 17th of August 2018. Unfortunately, the change log files don't provide detailed information about the changes:
Native driver
v3.0.0.5 2018.08.17
- add new cameras
v3.0.0.4 2018.05.04
- add 120MM-Mini
v3.0.0.3 2018.01.22
- add 1600GT
v3.0.0.2 2017.10.12
- add 294MC
- fix driver date
ASCOM driver
v1.0.3.21
- Update SDK to V1.13.0821
- Fix some bugs
v1.0.3.18
- Add "Advance" option to "Setup" Dialog
v1.0.3.15
- UI of pre-defined setting changes
v1.0.3.12
- Add unity gain mark to gain label
- Add support of R/W camera ID
Also there was no thread about the new versions in the "SDK & driver" board.
I would like to know:
1) Is the bad bias stability with ASCOM v1.0.3.18 a known issue?
2) Has the bias stability been restored again?
3) Which bugs have been fixed in the ASCOM driver 1.0.3.21?
4) Is the update to SDK 1.13.0821 important for the usage of an ASI294MC Pro?
Please reply to my questions. I will have to decide soon whether to revert to the ASCOM driver v1.0.3.12 or update to v1.0.3.21.
Bernd
