With INDI / EKOS, the ASI1600Mm fails after a few image downloads. This happens regardless which USB cable I use, or which port (USB2 or USB3).
In INDI / EKOS I keep getting the error: "ASIGetExpStatus failed" after two to ten images.
I have set the USB speed to 40, and tried different cables and ports with no effect. I can only get 10 images max, and then have to turn off everything and reboot. Everything else on the NanoPC T4 works great, and all aspects of KSTARS and EKOS works well with my Lubuntu OS. If I switch over to another CCD camera, it works fine. Only the ASI1600Mm fails.
