Mount
No drop down list to select a mount is shown on the opening page.
I know the mount is connected as I can connect and control in Sky Safari.
After entering program, I can open mount control even though the icon is grayed out. After a couple tries I can get the dropdown list there, and select my mount. Then it prompts for position. After completing this page, I can return to the preview page and the mount control appears.
Trying to use the mount control in AIR is difficult as it is not very responsive. Keys either don't respond, or stick. Controlling the mount from Sky Safari is smooth and responsive,
Capture
After focusing I return to preview and set the desired exposure. When I click on capture it says exposing, then downloading. Upon checking the file with the icon at top right, I find the file empty. If I use the Ethernet connector and go to \\ASIAIR there is nothing there.
I'm not sure what the file icon on the lower right is for. Clicking it after an exposure it says saving, but there is still nothing in the file. I have used Android screen capture to save images.
Auto
When I go to auto and set up a script I can find no way to save it, or execute it. If I go to preview and click capture it doesn't run the script. When I return to auto, the script I had created is gone.
Plate Solving
Having never used this before, I am uncertain how many stars it needs to work with. What is a good number, or good exposure settings to start with?
Thank you
