Has anyone moved slider temp control bar , when ASIAir working autorun mode capturrng image?
When I did that, current autorn batch was ended force.
After that, next batch was automatically run.
No error or warning message was appeared and batch defined number of fit files were saved .(file size is the same as normal one,but not shooting stars)
Sympton example
R,G,B autorun batch create.ie frame,2min,5frames
Cooler temp setting is -30degrees.
When R batch is running,move slide bar to -25degrees.
Capturing will terminated and G batch will run normally.
Thanks
Japan
ASI1600MM-Cool,Rev2
