I've had my ASI294MC Pro for since last December and have a question about cooling. I am using a 5 amp power brick to power the cooler and with an ambient temperature of 16.2c (measured with a TemperHum USB unit in one of the camera's USB2 ports). The camera will not cool to -20c, it stops at around -17 to -18 and fluctuates using 100% power.
I thought the expected delta was 40c so at ambient +16c the camera should be capable of cooling to -26c. I want to image at -20c and be able to generate darks etc at -20c in the daytime. Is this unreasonable to expect of this camera? Also ASICAP 1.4.1 seems better at controlling the cooler than the ASCOM driver (I use APT to capture deep sky subs).
A second point. The ASCOM driver defaults to an Offset of 30 and ASICAP to 8. Which is correct?
Thanks
Duncan Evenden
Manche, France
