1) Is it possible to use the Ethernet connection rather than the ASIAir WiFi network to connect the app? I have tried plugging in the Ethernet, being connected by WiFi to the same network as the Ethernet and starting the app but it keeps asking for you connect to the ASIAir WiFi directly? Seems a shame as it would allow remote operation? It would also give you a mechanism to allow a WiFi password change as if you forget it, you can always get to the device by Ethernet.
2) will you add dome and focused support? It’s already there in INDI so presumably just means exposing it in your UI? I guess you might need to allow python for the Dome Scripting Gateway where the dome is not natively supported (like mine!).
Thanks
Simon
