the image saved in raw only, debayer is for preview only
>I can not access the image files via wireless or via Ethernet cable ( \\ASIAIR ) .
are you sure you power on AIR and your PC and AIR under same network?
I cannot access \\ASIAIR from a MacBook using Safari, or Edge, or Chrome.
Anyone accessing OK who can advise me?
thanks,
Bob Minor
Hello,
If you have Windows PC,
Connect to ASIAir wifi and select run program ment on start menu inpxt and run as \\ASIAiR (all are upper case letters)
So, you will found Images holder.
Sorry, you use MAC PC, not Windows PC...
1.you need to connect air's wifi
2.in the left-top corner,click goto and connect server
3.input 10.0.0.1
rhminor wrote:I cannot access \\ASIAIR from a MacBook using Safari, or Edge, or Chrome. Anyone accessing OK who can advise me? thanks, Bob Minor
1.You need to connect ASIAIR's wifi
