Sorry for a feature request again.
Could you consider add a feature of very simple network router and bridge, wifi to Ethernet with DHCP Server?
This will enable another devrice(server) co-exsistance by connection via ASIAir wifi network.
If your development load work is permrtted..the priority is low,because I think via Ethernet to ASIAir that discussed another topic will enable the same way (In this case ,must need additional wifi router in 10.0.0,x network)
Best wishes
