If you have horribly shaped stars, its more likely you are using a lens with bad coma. If you are unable to achieve focus, then its likely a spacing issue. Can you post a picture of the stars? Most canon lenses require you to go down a stop or two to get round stars across the frame. You can stop down the lense by having the camera on, setting the f-stop on the camera, and pressing the DOF button. Then, while still pressing the DOF button, take the lense off the camera. This "freezes" the iris at that F Stop.
