Hi - I’ve just noticed that there is a new camera dependent driver setting in the X2 driver. This appears as “ZWO Exposure Mode” and has two settings, “High Speed Mode” and “Long Exposure Mode”.
I found that I got a number of timeouts with the HIgh Speed Mode.
I couldn’t find any documentation for this setting - can you give a little guidance on what these modes are and when to use them?
Thank you very much,
Colin
5 days later
Hi Colin,
Sorry for this issue.
For you description, it should means video mode(High speed) and snap mode(long exposure). I am also not sure what it happened.
For the timeout, we will update this driver recently. This problem should be solved.
Thanks
Chad
Write a Reply...
