Hello Group
Is the filter holder disk in the 7-36mm EFW easily removed and replaced? I would like to remove it in order to block one position to enable taking darks as needed. I would then replace it with filters and plug installed. It might make mounting the filters easier as well.
A wheel with one hole missing would be nice but my plan is to block it myself then test for light leaks.
Is there a better way to do this? Am I over thinking this?
Ray J
