Lead_Weight wrote:
The ambient temperature in my home is around 23°C. I cannot get either my ASI071MC Pro or ASI1600MM-C to cool to -15C. I can get them to cool to about -13C and can't get it to go cooler at all. I'm using a 12v 5A power supply. Not sure how I can get to -15 or even -20.
The cooling degree of the TEC is limited when it is designed, so it is impossible to reduce the temperature without limit. Normally, this limit is 40 degrees Celsius below the ambient temperature. But the actual temperature difference would be less than 40 degrees, given the various factors such as ventilation, different heating from different sensors, and the efficiency of air cooling and so on.
So there's going to be a temperature range in our camera description, and the temperature difference is going to be normal in that range. For your camera, I think it is fine. If you want to get the lower temperature, you may need the external equipment to help it get a lower temperature.
Thanks
Chad
