Hi Bill,
For the gain, Only the unity gain is calculated.
For example, there is another camera.
when set gain=0, we can test the electronic gain is 1.5 e-/ADU, At this gain, we will get the largest full well capacity.
When we set the gain=60, we can test the electronic gain is 0.9 e-/ADU.
When we set the max analog gain=120, we will get the lowest read noise, at this point, the electronic gain is 0.2e-/ADU.
If we continue increase the gain, the camera will use the digital gain, the read noise and the electronic gain will not change, they just get amplified by the digital gain.
So LRN usually means the max analog gain is 120, it must be a correct value.
But for Unity gain. if we draw a curve with the data we tested, you will find the gain is around 50 when electronic gain is 1.0e-/ADU. But if you use the mathematical algorithm to calculate it, you may get 45 means electronic gain=1.0e-/ADU. But in the truth, maybe electronic gain equals 1.0e-/ADU when the gain is 46.5.
Please forget my poor drawing.
Thanks
Chad
