Hi Chad,
I don't understain you exactly , I writte under your mail , please anwser me:
Hi Xavier,
I think you misunderstand the monobin.
Its very possible , I have not a manual to learn how work this camera in this mode mono bin . Please explain me
For mono bin, it means when you only select it, it does not perform the operation.
what operation ?
If you also select Bin2, it will perform the bin2 in mono mode, ignore the color.
I don't understain exactly what you want said with " ignore the color ". when you select BIN2 whats pixels sum to obtain 4.059.024 pix ?, pixels with the same color , or diferent color ? for obtain a monochrome image ?
So for you method 2, it has no difference with select mono bin and bin4.
Probably
thanks
Thanks
For further clarification:
Option 1
Probably, the simplest way to convert a color image into a monochroma and maintain the maximal resolution of the camera, is to eliminate from the original file the information of the pixel of color to which each of the pixels belongs: R / G / B, and in this way deceive the system, creating a grayscale image, but this way is a little unreal, because the intensity of the light captured by a red pixel, or a green one, or a blue one, is completely different. And for only separation of 4.75 microns, which is the size of the pixel, it results that the created image is quite false when creating irregularity in the intensity of light captured by each pixel due to the color of its encapsulation.
Option 2
Another very different system would be that, for the creation of a monochrome image, the software would collect the information of the 4 color pixels and sum them, obtaining a virtual pixel of monochromatic value, therefore the native resolution of the camera would be reduced to 1/4 part, that is, in the case of the ASI071, it would pass from 16 Mpx to 4 Mpx, but without doubt the monochromatic image obtained would be much more real, as we all know that the white light is the sum of all the colors, and So what better way to obtain a "whites" / grays scale, than sum the colors of each Bayer matrix R + G + G + B?
That's why my question is to know what system ASICAP uses to create a monochromatic file starting from a color file at maximum resolution.
And the same question when you select BIN2 in MONO mode.
Use option-1 or option-2, or use another method, and in that case which method?
