Hi GrahamF:
You had asked
>> It has no go to functions and only tracks in RA so whilst it can be guided in the RA axis there are no options
>> in the guiding tab to select RA guiding only.
If you open the Guiding window, with the guiding Graph showing at the bottom of the window, you should see a row of text just above the graph that starts with "DEC Mode".
The other parameters on that line of text are DEC aggressiveness, RA aggressiveness and whether you want to see correction pulses in the guide graph.
"DEC Mode" is defaulted to "Auto" (shown in green; indicating that it is an item that can be changed by the user). "Auto" just means that DEC pulses will be generated (whether through pulse guiding, or through ST-4 guiding) for both North and South corrections.
If you click on the word Auto, it will cycle through "North," "South" and "None" and back to "Auto." With North and South selections, only north or south pulses will be generated.
What you are looking for is the "None" setting. With that setting, the PHD2 version in the ASIAIR will ignore DEC errors.
Clear skies,
