Hi,
I need help troubleshooting my ASI1600MM. It is not saving images consistently. I do not touch anything and let the whole set-up run for hours. I check to make sure images are being captured and saved. However, when I come back after a few hours, only a few images were really saved. For some reason some images save, and 90% do not.
Computer/software: Max OSX High Sierra
RAM: 8 Gigabytes
Camera: ASI1600MM-Pro
Software: ASICAP V1.4.1
Please note: When I did 15 minute individual exposures, no issues were noted. No problems at all. However, when I tried to do 200 second exposures (~3 mins) 90% of images did not save.
Yes, the recording button was on to save all exposures with no limit.
What is causing images to not be saved?
Is it a bandwidth problem?
Is it a software problem? If it is a software problem, why have I had no problems with 15 minute exposures with NO frames dropped? Why are frames now being dropped even though I haven't changed a single thing except exposure time?
Bandwidth and speed of download should not be the problem, as the computer should have several minutes to download the data, due to it being 3 minute sub-exposures.
Please help me understand what is happening.
Thank you
