Hello Sean,
I've looked into this issue further. It seems that the problem is with the FITs files that are downloading from the new ASI071. I'm using PixInsight and its STF to view FITs files. I never had a problem with viewing images from the original camera. However, when the STF is used to view FITs files from the new camera, the images don't display properly due to a light background and fewer stars visible. The background ADUs (from CCD Inspector) are over twice as high from the new camera as from the original camera.
It is possible to improve the appearance of the images from the new camera but it requires considerable manipulation of the sliders on the STF to adjust the blackpoints and midtones balance. The normal STF settings don't work and adjusting the sliders for each image from the new camera is too time consuming.
So it seems that the problem is with the histograms of the images from the new camera. They are very different from those from the original camera and don't display properly with PixInsight's STF default settings. This isn't a problem with seeing or focus because the images from the new camera actually have better (lower) FWHM values than from the original camera.
The scope is an SW150 with a field flattener and ZWO IRCUT filter. I made sure all the optical surfaces were clean. The settings for all images were: Gain 50, Offset 12, Gamma 50, Raw 16, Hardware and Mono Bin=0, X2 Driver 17.4.25 Version 2.000, ASI SDK V1,13,0,16
Here are Google Drive links to the FITs images at 120 secs from each camera. It's the same star field but the new camera images are rotated about 90 degrees and the images from the original camera are at ambient temperature because the cooling section wasn't working.
Original camera 120 secs. https://drive.google.com/open?id=1Rq36AtZD9b-JqVVkBHJAtQvYZt23GAS3
New camera 120 secss. https://drive.google.com/open?id=17Cczu3iUnx6L9kjATGsjBwD0bVmCFLJ0
Here are two more images from each camera with the same settings but 300 secs exposures.
Original camera 300 secs https://drive.google.com/open?id=1x3W-Kk2eSU0rw0vWEk7FYm0U5yYM4Mve
New camera 300 secs https://drive.google.com/open?id=1Q-SiKskHStGCU9r43bKFasK9EoMvXBH4
Thanks in advance for your assistance.
Michael
