I have determined after going out last night that ASIAIR is not going to work when I use my Celestron Star Sense. When I would finish the Star Sense alignment using Celestron WIFI I then would then connect to the ASIAIR WiFi and try to use Sky Safari to locate objects but the object would be way off. Sky Safari does it’s own plate solving and so does ASIAIR so there is an overlap on functions. I could go back to using my non Star Sense hand control but that would mean that I would have to do doing a 2 or 3 star manual alignment. I do not have an equitorial mount, guiding scope or guide camera and I don’t plan on purchasing anything like this for a while.
So I am going to return my ASAIR and go back to my original plan of using Sharpcap using Livecap which will require me to have to use my laptop which is what I was trying to avoid with ASIAIR.
For the ZWO folks,
If you ever decide to support an ALT-Z mount with Star Sense and Sky Safari, I wold be interstellar in taking another look.
