Update:
In the SGP Log files I find
Caught exception while getting filter wheel position. FW is expecting to be STOPPED! Returning (5) : set - '' is an invalid value. The valid range is: . (ASCOM.InvalidValueException: unspecified
bei ASCOM.EFW2.FilterWheel.get_Position())
bei ASCOM.DriverAccess.MemberFactory.CheckDotNetExceptions(String memberName, Exception e) in c:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs 553.
bei ASCOM.DriverAccess.MemberFactory.GetTargetInvocationExceptionHandler(String memberName, Exception e) in c:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs 664.
bei ASCOM.DriverAccess.MemberFactory.CallMember(Int32 memberCode, String memberName, Type parameterTypes, Object parms) in c:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs 231.
bei ASCOM.DriverAccess.FilterWheel.get_Position() in c:\ASCOM Build\Export\ASCOM.DriverAccess\FilterWheel.cs 111.
bei q6.ic()
and finally
Adding sequence level notification: Camera timeout! No image was downloaded.
Sending Notification: Warning - Camera timeout! No image was downloaded.
Best regards
rudolf
